oscillator is not working
angangry
Joined Jun 2, 2023
11
공통 기본 발진기가 제대로 작동하지 않습니다. L 및 C 구성 요소를 어떻게 변경해도 여전히 작동하지 않습니다. 무엇이 문제일까요? 트리거하기 위해 전류 펄스를 적용하려고 했지만 회로에서 어디에 연결해야 할지 모르겠습니다. 제발 도와주세요.
TRANSLATION: The common base oscillator is not working properly. No matter how you change the L and C components, they still don't work. What would be the problem I tried to apply a current pulse to trigger, but I don't know where to connect it in the circuit. Please help me [Moderator]
Ya’akov
Joined Jan 27, 2019
10,291
English is the language of AAC. Please make your posts in English in the future. Non-English posts may be removed. [Moderation]
angangry
Joined Jun 2, 2023
11
LvW
Joined Jun 13, 2013
2,035
I primarily use the 'Orcad tool', and in this software, the oscillator doesn't seem to work properly. Can you please explain how to apply a current pulse to the Tank Circuit?
You do not need such a pulse for starting oscillations (provided the circuit is able to oscillate).
Switch-on the power supplies at t=0 (start of the TRAN analysis) - and the switch-on transient is by far sufficient to start the process.
Danko
Joined Nov 22, 2017
2,231
Download books:
"ELECTRONIC CIRCUIT ANALYSIS USING LTSPICE XVII SIMULATOR" https://ebin.pub/qdownload/electron...ginners-1nbsped-1032040769-9781032040769.html
"LTspice IV Getting Started Guide" https://www.analog.com/media/en/sim...ettingstartedguide.pdf?modelType=spice-models
And many useful articles are here: https://ltwiki.org/index.php?title=SPICE_and_LTspice_Courseware_and_Tutorials
Can you please explain why this isn't working!?
Run .asc file from attachment.
Pay attention to details of .tran directive.
DickCappels
Joined Aug 21, 2008
10,661
Just a note: A real-life circuit will need a bypass capacitor across the collector supply batter and the base bias supply. The capacitors are not needed in simulators as far as I know, but you might want to add .001 uf capacitors.
angangry
Joined Jun 2, 2023
11
Download books:
Danko, You have been very helpful to me, and I appreciate it. Thank you!
May I ask another question? I have switched to the common base configuration in your circuit, but it is not oscillating at all.
I have tried changing the values of the inductor (L) and capacitor (C), but still, there is no oscillation.
Do you think there might be an issue with the circuit?
Additionally, I have also placed a resistor between the base and collector, but it also doesn't cause any oscillation.
Could you please provide me with some guidance on what I should do next? Thank you again for your assistance!
Danko
Joined Nov 22, 2017
2,231
Your transistor is staying without collector voltage and current because of capacitor C4 !!!!
For what you need C4 capacitor ???
Kash111
Joined Jun 6, 2023
9
That CB circuit works for Colpitts.
But it doesn't work for claps.
May I know the reason for this
I designed a CB clapp oscillator.
The circuitdoesn't work properly.
So I tried connecting the R2 resistor from the power supply to the collector, but the oscillation does not work properly.
This is my final assignment for my oscillator, and I'm getting lost here.
How should I solve it?
I'm having difficulties with the CB section of my oscillator project.:(
Danko
Joined Nov 22, 2017
2,231
