Optical Shutter Spike problem
ilginsarican
Joined Jul 13, 2017
147
I use I use this type of shutter:
Voltage to Open is 24VDC, It draws approximately 1.2A .
I use same 24VDC to feed my circuits.When I trigger the shutter,spike occurs on my ADC signal.
I know that using same DC line causes this problem ,but what kind of filter can I use?
Can I figure it out using any filter?
Sensacell
Joined Jun 19, 2012
3,786
When you have a noise problem- you need to consider:
a) Reduce the generation of noise- post the shutter coil driver circuit.
b) Reduce the sensitivity to noise- shield / filter things.
Do both for maximum results.
ilginsarican
Joined Jul 13, 2017
147
Here is the shutter drive circuit:
D15 is Schottky diode.
