Does SFP28 Optical Module Compatible to 16Gbps?
kyliu
Joined Nov 4, 2021
I have recently building a project and it require 16Gbps data rate. The FPGA board only has SFP cage, so I am searching SFPs online. But all of the SFPs not clearly state it support 16Gbps data rate. My question is can I buy a SFP28, which can run up tp 25.78125G, and make it run at 16Gbps? if not, are there any other options? Like a SMA coax cable?
lordofbeez
Joined Jun 27, 2026
I think you should be able to use a 25G SFP DAC. Its basically just a coax cable.
I dont think SFP optical modules are meant to work at different speeds, but I have seen 25G modules work at 10G and 1G. Might depend on the module.
What is the protocol of the interface? You may also need to ensure your output driver settings are setup correctly. SFP's are with a differential impedance of 100 Ohms. Some protocols expect a different output impedance. PCIe is typically 85 ohms IIRC.
Benz Karl
Joined Nov 17, 2026
I’d look at a short passive 25G SFP28 DAC first. It uses twinax pairs and has no CDR in the data path, although your FPGA transceiver and board routing still need to support 16 Gb/s.
Optical modules are more model-dependent. Some support lower rates with CDR bypass, but 10G/25G support doesn’t automatically include 16.000 Gb/s. I’d ask the manufacturer to confirm both TX and RX operation.
SMA is another option if you have a suitable differential breakout. Check the channel impedance, transmitter swing and equalization settings either way.
What FPGA board and protocol are you using?
We also have a general <Mod: link deleted> for background; the specific module’s datasheet is what matters for compatibility.
drjohsmith
Joined Dec 13, 2021
1,680
depends upon the sfp.
optical / fibre ones normaly have electronics that are frequency tuned,
wired sfp, such as cat6 , tend to accept any rate ( within reason ! )
DAC can by definition work can work down to dc , and is often the prefered method of initialy testing a board
