Optical fiber networking
Futurist
Joined Apr 8, 2025
950
I've often wondered why don't we see optical fiber more, as opposed to clunky network cables and connectors, look how cumbersome they are on otherwise small boards. Bandwidth and noise are far superior with fiber too and PC network cards that support fiber are cheap. Optical seems prevalent in the audio world, odd we don't see more of it in homes.
Ya’akov
Joined Jan 27, 2019
10,310
Fiber termination requires much more skill and more expensive tools. The fiber cables are less flexible and more prone to damage.
Fiber is more common than it once was but copper is simpler in many ways that ensure it will be more common for the foreseeable future.
38,858
Fiber is used, of course, to bring Internet into a residence, but usually it then goes directly to a WiFi modem.
My house was wired with Ethernet cables but I switched to all WiFi probably 20 years ago.
Certainly with WiFi now able to easily deliver several simultaneous high definition TV signals, and Mesh systems to carry the signal over a large area, there seems little reason to use a wired connection in most homes or businesses.
I assume most commercial buildings already are wired with Ethernet cables and there's no compelling reason to rewire with fiber.
Perhaps an option for new buildings though.
Where do you see the use of fiber optic in a building?
Futurist
Joined Apr 8, 2025
950
My question was mainly about the clunky connector sizes on the little MCU boards, the RJ45 sockets are relatively large when the board is small, being able connect it via fiber could make the device more petite.
38,858
So you still use Ethernet instead of WiFi?
38,858
No, but the MCU boards I'm talking about (see OP) often come without wifi, just an RJ45 and TCP layer, they could make those much smaller if they had an optical connector.
So what are those RJ45 inputs connected to when the MCU boards are being used?
I would think it's not a hard-wired building Ethernet cable(?).
Ya’akov
Joined Jan 27, 2019
10,310
Fiber optic dangerous to eyes. Don't give dangerous toys to hobbyists.
If you stick a fiber in your eye, possibly.
Gigabit LAN optics (SFP, SFP+, GBIC) are almost universally certified as Class 1 laser products under IEC 60825-1.
Class 1 means safe under all conditions of normal use, including direct viewing into the port from typical distances.
No one making the devboards in question is going to play gatekeeper for "hobbyists" and there is no regulation that prevents them selling fiber optic transceivers. Consider that very unsafe lasers are marketed to hobbyists for a few dollars.
Ya’akov
Joined Jan 27, 2019
10,310
Consider also that fiber switchgear is considerably less common and more costly than copper. In general, fiber is used for verticals and copper for horizontals. There are some applications, like certain AV setups and electrically noisy/sensitive locations, the use fiber horizontally.
eetech00
Joined Jun 8, 2013
4,731
There is never any need to look down a fiber cable. so DON'T look down the fiber cable.
You can easily tell if its receiving signal by holding the end near a (darker) object.
