What to expect without the optical fiber ?
Externet
Joined Nov 29, 2005
2,678
Setting a pair of these one in front of the other with sight of the optical ports aligned, no optical fiber ?
Would it be an over-the-air optical LAN link ?
----> https://www.aliexpress.com/item/6CO...pm=2114.10010108.1000015.2.3e3915096nS57k&s=p
Now, what to expect if the optical ports were fitted some lens instead of the fiber, like to diverge/sense a wider angle ?
Would some wider dispersion be achieved ?
wayneh
Joined Sep 9, 2010
18,173
It might work, with a much reduced signal to noise ratio and thus likely much reduced bandwidth. But the device might have some cutoff built-in, to throw an error if the light level is judged too low. Or to ignore light levels that are too low, meaning your signal will be completely ignored.
