Operating 12 volt SMPS fan using arduino and ULN2003
bertus
Joined Apr 5, 2008
23,005
That depends on the current of the fan.
The ULN2003 can have a short peak current of 600 mA and drive about 500 mA.
Bertus
Ishan Jain
Joined Nov 12, 2016
100
Yes,the current required by the fan is around 500 mA. So can you please provide me the circuit for the same.
Thank you
Ishan
Ishan Jain
Joined Nov 12, 2016
100
I am doing a project in which i m controlling a relay with 2003 ic, So i wish if i could control a 12 volt fan too. Please provide me the schematic if possible.
Thank you
MaxHeadRoom
Joined Jul 18, 2013
30,808
If using a mosfet, a relay is not required, also IF a relay IS used the the mosfet could still do the job, is the ULN used for other functions?
Max.
Ishan Jain
Joined Nov 12, 2016
100
I think you didn't get me sir, I m controlling relay with ULN2003 as I m working on home automation and I also want to control a 12 volt fan from ULN2003 so please provide me the connections for that as I have already used ULN2003 in my project.
Ishan Jain
Joined Nov 12, 2016
100
I m using relay for the bulb but the fan is DC so relay can't be used in this case. Therefore I require a different circuitry for that if ULN2003 is not suitable for this application then please tell me how can I drive the same 12 volt fan with L293d motor driver IC.
MaxHeadRoom
Joined Jul 18, 2013
30,808
See post #8, it shows a relay being driven by a ULN2003 the relay contact will switch the 12v supply for the fan.
What voltage do you have on pin 12?
Max.
Ishan Jain
Joined Nov 12, 2016
100
I m having 0.69 volts on the output pin of relay and thats why my relay is not workingcoz is not grounding the voltage. please helpme with that too
MaxHeadRoom
Joined Jul 18, 2013
30,808
You show the fan being switched from a 220vac source?
You will require a 12v supply if you want to switch a 12v fan.
If this is another fan, then you will need another 5v relay as well as the 12vdc.
Max.
Ishan Jain
Joined Nov 12, 2016
100
if I m using a dc fan of 12 volt then what amendments you will suggest in the existing circuit? whether I should connect 12 volt fan directly to the ULN ic?
djsfantasi
Joined Apr 11, 2010
9,237
What is the potentiometer for in the upper left of your diagram? Where is your 5V supply coming from? I don't see one in your diagram. How are you powering your Arduino? Using the 5V pin is not recommended to power the board; it can damage the Arduino by bypassing its internal regulator.
You don't need another relay to power the fan with a wiring change, but you will need a 12V power supply.
