Audioguru again
- Joined Oct 21, 2019
- 6,702
It is heating that causes a linear supply to be inefficient. Voltage across circuit parts times the current causes the heating.
A transformer voltage is RMS, but the bridge rectifier charges the main filter capacitor to the peak voltage (1.414 times higher) minus the peak rectifier voltage drop of about 2V. Since any more voltage than you need produces wasteful heating in the high current parts you should calculate how much voltage is needed and do not exceed it.
The transformer must provide enough voltage for the circuit and enough power (current) for the circuit plus for the heating.
On www.electronic-lab.com, there is a 0V-30V from milliamps to 3A laboratory power supply project that has been there for 15 years and is/was a kit. I helped fix its many overloaded parts and recently some Chinese companies copied its original problems. The original defective circuit is still at Electronics-lab and my fixes are in its notes somewhere.
For its 30V/3A (90W) output I spec a 28VAC/4.2A (120VA) transformer. Its supply is +37.6V and -1.3V. If its output is shorted or is set to almost 0V at 3A then the heating is 37.6V x 3A= 112.8W plus the 2V x 3A= 6W in its bridge rectifier.
The positive voltage is +37.6V because its output transistors and their emitter transistors need about 34V, the driver transistor needs about 35V and the opamp needs about 36.6V to produce 30VDC at 3A.
