Both units (Altai and this one) have a very similar transfor with two windings, one outputting only 6v ac (Altai has a higher Amp output), the Altai seems to use this lower voltage to power the op amp with looks to me half wave rectification.2 amp load 4.39v, 4 amp load 4.35v
Yes the transformer ac voltage does drop 2 volts on 4 amp load, but so does the Altai?I mean the 23 volt supply.
I at present am not using this lower second windingYes the transformer ac voltage does drop 2 volts on 4 amp load, but so does the Altai?
I tried using it a few days ago, rectified it full wave and used it to power my op amp circuit at @9v, my max output I think was 7vI at present am not using this lower second winding
meant to say the collector of both power transistors were connected to the larger 23v, I have something wrongI tried using it a few days ago, rectified it full wave and used it to power my op amp circuit at @9v, my max output I think was 7v
2vHow much does the 23 volt dc voltage drop under load
Audioguru stated the 23v single rail powering the op amp was too high, I agree with him.
I just unsoldered resistors, unfortunately got the same result as before, with Q1 also removed, look for datasheet nowI couldn't find any data on the op amp do you have a link?
https://www.ti.com/lit/ds/symlink/t...-digikeymode-dsf-pf-null-wwe&ts=1608509796457I just unsoldered resistors, unfortunately got the same result as before, with Q1 also removed, look for datasheet now
to what 6k?OK, if same results then you don't need those components.
Try reducing the 10K resistor on the shunt.
Hello again, Can I use a zener to lower the voltage to 18.3v supply for the op amp?I said the 2N2222 transistor should be removed and the minimum supply voltage should be +18.3V for the output to be 14.8V at 4A.
The voltage losses when the output current is high are in the 100 ohms resistor, the base-emitter voltage of the TIP41. the base-emitter voltage of the output transistors, the 0.1 ohm emitter resistors and the wiring.
The maximum output of the TLE2141 opamp is 1.3V less than its supply voltage so the voltage losses are 18.3V - 1.3V -14.8V= 2.2V. If the opamp had infinite voltage gain then the output voltage would not drop when the load current is high but the minimum voltage gain of a TLE2141 is only (!) 100,000 divided by the voltage gain of 5 times you want so it can reduce the voltage loss by about 20,000 times to 0.1mV. The wiring makes a much larger voltage drop.
There is a slight improvement even now on the 4amp draw at 12v output....earlier the 12v dropped to 11.89v...........now 11.92vHello again, Can I use a zener to lower the voltage to 18.3v supply for the op amp?
