All opamps can operate from a single supply. We need to know more about your application; in particular, frequency and input/output amplitude requirements.Im looking for a opamp for single supply (GND-12V), Dip8.
There are many devices specifically for single rail - but it wasn't always that way.Hi all,
Can someone advise on a common op amp that works?
thanks
Very true statement.All opamps can operate from a single supply.
Single supply opamps can also use split supplies, but the outputs have to be connected to the negative supply to minimize crossover distortion.So-called "single supply" op amps are merely those which have features that make them easier to use in a single supply application.
Did you ever get around to making the spreadsheet?This thread, Which Op Amps Do You Use?
Yep. See here.Did you ever get around to making the spreadsheet?
Thanks. I liked that post, so I must have downloaded the files. I just searched the previous thread you referenced.Yep. See here.
I made that list of op amps, but never got around to doing what I originally said I would do: write up a guide to op amp data sheet specifications, what they mean, and which ones to pay attention to when designing something. I made a list of the op amp parameters I intended to cover, but never got beyond input common-mode range; I probably should get off my hindquarters and finish it.Thanks. I liked that post, so I must have downloaded the files. I just searched the previous thread you referenced.![]()
I'm retired and I still put things off. I spent most of my life doing things to make others happy. Working mostly for myself now, I figure I've earned the right to do what I want to do; as much as possible.I probably should get off my hindquarters and finish it
Same situation here. I retired five years ago and have been enjoying life for a change: no more deadlines, no more schedules or having my work be in a project's "critical path," no more "objectives," no more progress reports, no more departmental budgets, no more clueless but demanding bosses and no more sub-par co-workers who don't pull their own weight.I'm retired and I still put things off. I spent most of my life doing things to make others happy. Working mostly for myself now, I figure I've earned the right to do what I want to do; as much as possible.
