How does connecting the sources via voltage followers to the input of difference amplifier enhance its performance?
Following is the excerpt from Microelectronic circuits[6th Edition] by Sedra smith:
The low input-resistance problem of the difference amplifier can be solved by using voltage followers to buffer terminals: that is voltage follower is connected between each input terminal and the corresponding input terminal of the difference amplifier.
Please explain it.
Thank you
Please explain it.
Thank you
