Op Amp Circuiit Questions
MoonLight94
Joined Oct 30, 2015
2
Hello there I have a problem with this questions I hope if u can help me with them :)
My problem is how to get Vo in these questions ..
first one because of the non inverting feed back
and the second one is because of the Complexity of the circuit ..
and the in advance
33,137
MOD NOTE: Moved to Homework Help (because it looks like homework).
If this is homework, you need to show your best attempt to solve the problem. We can then look at your attempt and identify what you are doing right and what you are doing wrong and help get you on the right path.
33,137
great I'll Do my best, but i really don't know from where to start with the non inverting feedback
Remember that what you are looking for is an output voltage that is stable for the given input (since this isn't an oscillator, hopefully). Also keep in mind that the output voltage is limited to being between the power supply voltages.
RBR1317
Joined Nov 13, 2010
715
Analysis of an op-amp circuit wired for negative feedback always starts with the realization that the voltage difference between the op-amp inputs is just a few micro-volts. For an ideal op-amp with infinite gain, the voltage difference is 1/∞ or zero.
