The number of “LED Groups” is the best way. Either obtain the current requirement of one group from the specs. Or measure the current drawn by the entire roll and divide by 100 (number of three LED groups assuming 3 per group in a 300 LED roll). Or cut off one three LED group and measure the current drawn.Maybe just base the current on the number of LEDs, instead of using the length….:-|
The add says:The ad for the LED strip says to use their 12V/2V power supply for all 300 LEDs. Is that true or is it false?
makes no sense whatever. 1 foot can still be operated at 12V and 2A. But as I’ve shown. 1’ will need 12V and 80mA…But this, Foot will still Take 12 Volts at 2 Amps
One foot of the strip will only draw as much current as it needs off the 2A supply. It does not mean that it will draw the full 2A. The 2A rating of the supply is to tell you what it is capable of supplying.Can somebody help me Understand something about these LED Strips?
They Told me the LED Strip Takes 12 Volts at 2. Amps.
And even if I just need 1. Foot I can Cut 1. Foot Off.
But this 1. Foot will still Take 12 Volts at 2. Amps.
Is this Right I thought 1. Foot would need Less Current because they are in Parallel?
No, that is not correct. As several of us have tried to explain, the entire strip is a series/parallel circuit. Typically, the LEDs are wired in series in groups of three, plus a resistor. Then, these groups are all wired in parallel.Every LED in the 16 Foot Run is in Parallel am I Right?
BobIf 16 feet of LED strip requires 3 Amps, how many Amps does 1 foot require?
NO! I'M DONE WITH YOU!Every LED in the 16 Foot Run is in Parallel am I Right?
3 Amps / 16’ = y Amps / 1’If 16 feet of LED strip requires 3 Amps, how many Amps does 1 foot require?
BobIf 16 ft of LED strip takes 5A, how may feet will take 2A?
