djsfantasi
- Joined Apr 11, 2010
- 9,163
Yes… assuming you’ve cut the four feet correctly.So if 1. Foot will Take 0.333mA then 4. Feet will Take 1,332mA am I Right?
When you see 25mA write 25e-3AI know if you See 25 mA you will Write it like this 0.025 A.
And if you See 325 mA you will Write it as 0.325 A.
In the case of using just two decimal places, 0.33 for example, I'd read that as 330mA. Using 333mA is insignificant in comparison as you're only eliminating 3mA from the total value. However, this could add up. And NOT using the three decimal places can lead to confusion. If you told me you're calculating that at 33mA I would assume you mean 0.033A, and not 0.33A.Yes, you are correctly calculating the current from the wattage. It is one third of an amp, which is 333mA. Three digits of precision is more than enough, two is usually sufficient when calculating parameters in a circuit.
I agree with your Math.Ok thanks for all the help I think I Understand how to use the Math to Find the Power Supply I need?
I just want to Tell you and See it I have it all Right?
My LED Roll is 16.4 Feet and is Rated 12 Volts at 3.5 Amps.
So I want to know how many Amps I would need for just 1. Foot I would do this.
3.5 Divided By 16.4 = 0.2134 Amps.
Not if I need 4. Feet I do this.
0.2134 Times 4. = 8536 Amp.
Now just to be on the Safe Side would I Pick a Power Transformer Rated at 1.5 Amp Output or 2.5 Amp Output?
My LED Roll can be cut every 1. Foot. But the last one or two LEDs won’t light, the first or first two LED on the other strip will immediately burn up and I’m lucky if the wire connector works. You must have a different LED strip. Or not.my LED Roll can be Cut every 1. Foot.
First, 8536 amps could never read as 1 amp. Think about it would the weight of 8.5 cookies be the same as the weight of 1 cookie?My LED Roll can be Cut a Little over 1. Foot.
And yes I Cut a Small Piece just to See if it worked and it did.
So if 1. Foot will take 0.2134 Amps then 4. Feet will take 8536 Amp.
And Yes I know I would go for a Power Supply Rated around 2. Amps.
But am I Right with the Math 8536 Amps would be Read as 1. Amp?
0.8536A (853.6mA) Call it 854mA, for the sake of 6/10 of a milli amp. We all make mistakes.First, 8536 amps could never read as 1 amp.
Different manufactures will invariably have slightly different lengths for their cut points. And again, you forgot the decimal point. Unless you're doing something wrong with your math. 85376 amps at 5 volts would produce over 42 Killo Watts of heat. My fireplace might produce that much heat. Maybe not. I have no idea how many watts of heat energy my fireplace produces, but eighty-five thousand three hundred seventy-six amps is a heck of a lot of amperage. I'm sure you forgot the decimal point. 0.2134A times 4 is 0.8536A. Less than one amp. But for sake of headroom - go with a PS that can deliver 2 amps at 12 volts.My LED Roll can be Cut a Little over 1. Foot.
I agree! And I understood what he meant. But as WBahn often said, track units, track units, track units. I would have let it go, but this is not the first time the TS made this mistake. He’s posted this “mistake” more than once. I thought, without malice, that this indicated a lack of understanding on the TS part. Sorry.0.8536A (853.6mA) Call it 854mA, for the sake of 6/10 of a milli amp. We all make mistakes.
That can't be right. IF one foot draws half an amp then 16 feet will draw 8 amps. I'm sure your power supply doesn't push 8 amps of power. That's 96 watts (12V x 8A). Maybe your supply delivers 3 amps. That's what mine does, and it's also 16 feet. That's 231mA per foot (roughly). So if you're thinking about cutting your strip AT 12 inches; you're going to not get the full set of LED's to illuminate. You ONLY cut them at the points where I showed you in post #31.Am I Right just 1. Foot of this LED Strip will Take 12 Volts at Half an Amp?
