I posted on this Hitachi HA-4700 prev. on AAC:
https://forum.allaboutcircuits.com/...linear-ckt-design-please-help-explain.210716/
Serv. manual is here:
https://archive.org/details/manual_HA4700_HITACHI/page/n1/mode/2up
To cut to the chase, the LEFT CHANNEL seems to be acting (biasing) fine -- slowly ramping up to 7.7mV per serv manual, and holding there when warmed up-- despite , me having substituted in power transistors [Sanken 2SB1570/2SD2401 Darlingtons] that are NOT ideal for purpose. (That's all I have in my parts bin. Original replacements parts are difficult and $$ to acquire ).
Orig. Fujitsu 2SA1075/2SC1075 (both are BJT, non-Darlington )
My replacements for both L/R channels (currently installed): Sanken 2SB1570/2SD2401
I am not sure why the LEFT CHANNEL works (with decent sine and square waves), topping power at almost 80W!!
The RIGHT CHANNEL is not okay. Can't achieve bias above 0.0mV. Not sure why.
One reason for RIGHT CHANNEL issues might be the non-ideal choice of output trans. devices.
Note that the Sanken Darlingtons have DC current gain (hFE) much higher than the 2SA1075/2SC1075. I seem to have been able to control that with the orig. circuit, using traditional bias trim pots.
But I'm not sure why L channel is working.
ChatGPT reply to comparison query, compare "2SB1570 and 2SA1075":
The 2SB1570 and 2SA1075 are both PNP power transistors, rated for high current, but they have a crucial difference: the 2SB1570 is a Darlington transistor, while the 2SA1075 is a conventional single power transistor. That difference affects drive current, voltage drop, switching behavior, and whether they can be substituted for each other.
1. Specifications compared
Sources: Sanken 2SB1570 specifications and 2SA1075 datasheets. Specifications may vary by manufacturer and test conditions.
2. The key electrical differences
2SB1570 — high gain, low drive current
2SA1075 — conventional transistor, faster drive response
fujitsu semiconductor
3. Can you replace one with the other?
Generally, no—not as a direct replacement.
Even though both are PNP devices rated at 12 A, their gain and base-drive requirements are substantially different. Replacing a 2SB1570 with a 2SA1075 could leave the transistor under-driven; replacing a 2SA1075 with a 2SB1570 could change bias, voltage headroom, and switching behavior. The pinout and safe operating area must also be checked.
For an audio amplifier, the difference in base-emitter voltage is particularly important because it can affect bias and crossover distortion.
4. Which one is better?
Sanken Electric
Sanken Electric
+2
Sanken Electric
+1
+1
| Parameter | 2SB1570 | 2SA1075 |
| Transistor type | PNP Darlington | PNP single transistor |
| Collector-emitter voltage | −150 V | −120 V |
| Collector current (max.) | −12 A | −12 A |
| Power dissipation | 150 W | 120 W |
| DC current gain (hFE) | 5,000–30,000 | 40 min. at 7 A; 60–200 at lower test current |
| Saturation voltage | −2.5 V max. | −1.8 V max. |
| Transition frequency | 50 MHz typical | About 45–60 MHz, depending on manufacturer |
| Package | MT-200 | MT-200 |
| Typical application | Audio output stages, regulators | Audio power amplifiers, high-speed switching |
- Extremely high gain means the driver circuit needs very little base current.
- Its Darlington structure produces a higher base-emitter voltage drop, typically around two junction drops.
- Can be useful in power stages designed specifically for Darlington output transistors.
- Requires more base current than the Darlington.
- Has a lower base-emitter voltage drop, typically around one junction drop.
- Designed for high-speed power switching and amplifier applications.
- For a circuit designed around a Darlington: 2SB1570.
- For a circuit requiring a conventional, fast power transistor: 2SA1075.
- For a repair or substitution: Choose based on the original circuit design, not just the maximum current and power ratings.
Sanken Electric
Sanken Electric
+2
Sanken Electric
+1
+1
