Odd Transistor Circuit Solution
SamR
Joined Mar 19, 2019
5,534
Was given this question:
So, I worked the problem and almost came to the same solution. But, VsubCE = VsubCC - IsubC*RsubC. And I calculated 4.05V. It's not in saturation. IsubC is 16.1mA by may calculations and IsubCsat from the PDF is ~0.2V. What I don't understand is the key's VsubCE solution. They are taking the (what I calculated as) VsubCC and subtracting what I assume is the normal forward bias Voltage drop across the PN junction. But it is Reverse Biased! The circuit is not saturated so shouldn't the Voltage C to E be almost the full 3.35V? I did come to the conclusion that no parameters were exceeded.
MrAl
Joined Jun 17, 2014
13,780
Hi SamR
Looks like they made a mistake. If you have 4.05v at the collector and the emitter is grounded, then the Vce must be 4.05v and there is no way around that.
Maybe they got confused about the difference between the base and collector. The base is 0.7 above ground and you subtract that from the input voltage to get the base current but you dont do that with the collector voltage.
The only way that yellowed part could be true is if there was a diode in series with the emitter to ground and of course it was forward biased. That would also reduce the base current.
SamR
Joined Mar 19, 2019
5,534
K, I assumed it was erroneous but wasn't absolutely certain I hadn't missed something. Not the first error I've run across with this book... Yep, I'd already calculated IsubB to get IsubC. In fact, everything I calculated matched but the entire VsubCE part of the answer didn't jive. K, thx for the confirmation!
Audioguru again
Joined Oct 21, 2019
6,826
You cannot buy a transistor with "the maximum specified hFE". Instead you buy hundreds and test them all so you can be lucky and find one that has "the maximum specified hFE".
If you buy one transistor then it probably has "typical" hFE but it could have minimum or maximum hFE.
MrSalts
Joined Apr 2, 2020
2,767
Sounds like a new binning service could be implemented.
Back in the day, Motorola used to put various color dots of paint on the power RF transistors to indicate gain. Pink, Yellow, red, blue and green were the dot colors and could come with one or two dots. I have no memory of what range each color represented. You could order matched sets. Some distributor started the binning but Motorola eventually started offering matched pairs in-house for a premium price. You could buy pairs or quads of matched parts.
Audioguru again
Joined Oct 21, 2019
6,826
Transistors are rarely used at a certain hFE since the hFE of a transistor part number is a range of numbers. An emitter resistor adds some negative feedback so that the range of hFE works fine.
SamR
Joined Mar 19, 2019
5,534
The equation would be correct for calculating Vcb, not Vce.
I guess I'm having a hard time understanding exactly how the reverse bias Vcb barrier potential is 0.7V. Forward yes, but not reverse? Also, still a bit cloudy about when Vce(sat) is 0.2V and you have the V across Rc =IcRc that it doesn't add up to Vcc? In fact for Vce you have 2 barrier potentials Vcb and Vbe. Still hasn't gelled for me as yet.
MrAl
Joined Jun 17, 2014
13,780
Vce doesnt have any barrier potential unless the voltage drops below the base voltage. When Vc drops below Vb, then the collector itself starts to draw current away from the base. That's why we often state that for saturation you should think of the transistor as having a Beta of just 10.
So for Vb=0.7v and Vc=4v with the emitter grounded, the CB junction is reverse biased so only the leakage current flows. When Vc drops to 0.7v nothing else happens, but when it goes below 0.7v then it starts to draw current away from the base. It actually wont draw too much current until the collector Vc gets down to around 0.5v (with base still at 0.7v) and then it may start to make a difference, but the more significant is when it gets down to 0.4v below the base, so in this case that would be 0.3v, and then it will start drawing more current away from the base. That action makes it look like the transistor now has less gain (Beta) and that's again why the rule of thumb is a Beta of 10 for saturation.
Note however really good quality bipolar transistors will behave better than this. They could hold the Beta higher due to the way they are made, and have significantly less Vsat..
I think maybe you would do well to look at a simplified model of an NPN bipolar Transistor.
Do you know how a current controlled current source works?
You could set up a circuit with two regular diodes like 1N4148 and a current controlled current source and see how this all works first hand in a simulator. It's very interesting to look at and think about. Once you do this i am betting you will never have another problem figuring out how this works.
I can post a schematic if that helps. It's just 3 components, and some input source like a current source or resistor and voltage source.
Danko
Joined Nov 22, 2017
2,231
It looks like that:
EDIT:
Since the CB junction is reverse biased, the transistor is operating in active mode vs. saturation.
V(C,B) curve added to diagrams.
dl324
Joined Mar 30, 2015
18,453
The problem is \(V_{CE}\). Did you write that or was it provided?
By the calculation, it's obvious that it's calculating \(V_{CB}\). Since the CB junction is reverse biased, the transistor is operating in active mode vs. saturation.
If you use LaTeX, your text would be easier to read. This:
becomes this:
\(V_{CE} = V_{CC} - I_C*R_C\)
SamR
Joined Mar 19, 2019
5,534
Not at all other than using a resistor.
Unfortunately, the diode models for LTS are not available...
Please do.
I'm going to spend some time simulating and breadboarding and taking measurements. I need to better understand the Vce as the transistor comes out of cutoff and reaches full saturation.
dl324
Joined Mar 30, 2015
18,453
A more accurate way to determine if a transistor is in saturation is to measure the CB voltage. When it's reverse biased, the transistor is in active mode. When it's forward biased, the transistor is in saturation mode.
The transistor is out of cutoff mode as soon as the BE junction is forward biased.
38,728
Here's a simulation showing the characteristics of a typical NPN BJT from cutoff to saturation versus the base current (horizontal axis):
The transistor goes from the active region to saturation when the Vce collector voltage (green trace) becomes less than the Vbe base voltage (yellow trace) at about 48µA base current with a collector load current near its maximum of 10mA (blue trace).
Notice the (Vce - Vbe) or Vcb voltage (red trace).
dl324
Joined Mar 30, 2015
18,453
I don't think I ever used the Insert->Math option.
For complicated things or many lines, I prefer to use Word or Writer.
This is from Writer:
As I recall, Word is easier. But I don't have it on the computer I'm using.
SamR
Joined Mar 19, 2019
5,534
@crutschow Would you post the .asc file please. LTS update seems to be having a problem with my libraries and wants a reinstall. Always something to add to the vast to-do list.
