Jon Chandler
- Joined Jun 12, 2008
- 1,613
Nice work!
I assume on the boards that need a “1”, you have the provision in place and I should simply solder a connection over the jumper?Nice work!
Here is the connection diagram I posted on the previous page. You may have missed it because I posted a thumbnail to click to make it full size.
From your pictures, it looks like you have some janky connections for pin 17, the common supply to the board. No. Connect pin 17 to the upper terminal block as I showed please. If you feel the need to fuse +12v, fuse it where it feeds into the driver board.
I haven't connected pin 17 yet. I will follow your instructions and connect it to the common wire from the light board.
The "1"s are connected to the upper terminal block as shown. A solder jumper on the two boards connected to a "1" must be shorted with a blob of solder depending on which side of the scoreboard it's on.
Understood.
The LEDs must be inserted with the positive terminal to the positive common connection on the board. DO NOT POWER THE SYSTEM UP WITH INCANDESCENT BULBS IN THE DIGITS.
Understood.
As I did state, the I2C interface between the boards should be as short as possible. Extending the wires between the driver boards and digit boards may be required to keep the interface distance short. Try it as you have it and see.
Understood. I have a kit for making RJ connectors, haven't used it in a while, but I'm sure I can sort it out. Any suggestions on the type of wire to use? Cat5? Cat5e? Cat6? I have access to plenty of most options.
I admire how quickly and nicely you've gotten the boards put together. But please, ask questions and don't get creative if something isn't clear. I'm sure I haven't explained every detail well enough at this point.
Thank you, it is a project I have been wanting to do for several years. I will post again as progress is made, I will finish up the boards ASAP.
As this progresses, I have looked and found LED bulbs that are 12v that can screw into E26 bulb bases like I have. Is that an option going forward in order to indicate AM/PM and the solstice/equinox functions? I assume another custom board would have to be made to those functions.
I currently have a student who loves programming working with the Arduino. He has a completed driver board, the Arduino, the expander chip and the clock chip. He thinks in couple days he could knock out a simple program.
Will do.You'll need a break out board from the RJ45 to header pins at the Arduino end. And some female-female Dupont jumper cables.
The schematic shows the connections. Signals will be connected to port pins on the Arduino.
Pin 1 connects to the Arduino's SDA pin
Pin 3 connects to the Arduino's SCL pin
(Please watch a video on using the Arduino to control an MCP23017 to see how the I2C interface works. The Arduino I believe has internal pullup resistors but external 4.7k pullups may be better in this case.,)
Xbox power supplyPin 5 connects to the Arduino's +5 volt pin.
(I have no idea what you're using as a power supply or if you've connected +5v to each driver board. But that supply should provide +5v to the Arduino.)
UnderstoodPins 7 & 8 connect to port pins (digital i/o pins), each of which control one of the "1' boards (assuming solder jumpers were made on the associated driver boards as previously mentioned).
Connect any one of the ground pins to the Arduino's ground pin.
Make the connections between ONE DRIVER BOARD and the Arduino and BEEP THEM OUT BEFORE APPLYING POWER. Test with only one board connected and develop code with only one board connected until things are figured out.
Power supply is hooked up, Xbox as recommended. Power supply feeds to a wired into a maxi fuse block, then to a distribution block and is split into the following (5V, 12V, 12V, Ground, 5V, 12V, 12V, Ground). The first (5V, 12V, 12V, Ground) feeds the top displays and driver boards, the second (5V, 12V, 12V, Ground) feeds the lower displays and driver boards.I am extremely uneasy about this project because I don't have much idea of what you've got hooked up and how......
I definitely hope not! Pin 17 is the +12V common connection for the LEDs on the digit boards. Please review the attached drawing to understand what's going on - the MOSFETs on the driver board provide the ground connection for the LEDs. Verify LED orientation and test method (with driver board unplugged) to verify LEDs.I get no continuity between ground and connection “17”
I got it now. Typically in automotive, common is ground or a shared path to ground. I see now what the configuration is. Thank you!I definitely hope not! Pin 17 is the +12V common connection for the LEDs on the digit boards. Please review the attached drawing to understand what's going on - the MOSFETs on the driver board provide the ground connection for the LEDs. Verify LED orientation and test method (with driver board unplugged) to verify LEDs.
Hope you have a lot of spare time over the next year.Let's see....
Hindsight is always 20/20.......Hope you have a lot of spare time over the next year.
| D | Running Low-Ohm Meter circuit in parallel | Test & Measurement | 19 | |
| A | Basic Electrical question problem (resistor network) | Homework Help | 10 | |
| E | Voltage regulator question | Power Electronics | 18 | |
| Y | smith chart logical problem question | Wireless & RF Design | 0 | |
Problem with Electrical Circuit Question | Homework Help | 8 |
