Not sure whether 4V is the thevenin's voltage for the load resistance.
studyhard24
Joined Jun 20, 2022
35
My approach:
We find Thevenin's resistance
Using the node analysis approach figure out Thevenin's voltage. And finally the current through the load resistance.
Am I doing it correctly?
Any suggestion or advice is highly precious to me, thank you
MrAl
Joined Jun 17, 2014
13,896
My approach:
I checked your result and got this:
1.2631578947368 Amperes
That is close to yours and if you round to 3 digits you get 1.26 but if you take 4.36/3.45 you get 1.263768115942029 which is different than the result i got. The difference is probably from rounding, but you may want to check using more accuracy.
