N5227B PNA measured two lines loose coupled was s31 -40dB while the other line s31 -20dB i noticed that the weaker s31 has noise distorting its phase.
I am using mxpm70 connector to test the lines.
What could be the source of the noise ?is terminating the other mxpm70 female connector will help?
will increasing pna power from -5dBm to -3dBm help to reduce the phase distortion of te noise?
