non inverting OP-Amp used as comparator
gerdomerdo
Joined Apr 2, 2021
9
In the schematic below:
The circuit is behaving as a comparator. When V+>V- the output is at 12V. When V+<V- the output is 0. (the positive pin power supply of the op-amp is connected to 12V and the nagative pin power supply is connected to ground).
The problem is when I try to do the math derivation to justify the behavior of the op-amp, I don't get what that comparator effect.
Here is the math derivation:
At V- (pin6), we have 6V because of the voltage divider R33/(R31+R33). Which means that we should get 6V at the V+(pin 5).
To make it simple, no currents flow in pins 5 and 6 (in reality there are some pAmps). the current flowing in R35 is (7V-6V)/R35=0.14mA.
then this current is flowing also in R34, since V5 is at 6V, the voltage at pin 7 (the output) is 2.93V (20kR*0.14mA). In LTspice I got at pin 7 12V.
I would like to know how I can justify the behavior of such circuit.
LvW
Joined Jun 13, 2013
2,031
@LvW , that's how an amplifier operates when there is a feedback, it tries to maintain the V+ and V- at the same potential
Yes - that is correct, but for NEGATIVE feedback only. Positive feedback causes saturation and the mentioned rule does NOT apply anymore.
gerdomerdo
Joined Apr 2, 2021
9
Ah okay , but can we prove it mathemtically ? I mean how can we reach the saturation in this case.
LvW
Joined Jun 13, 2013
2,031
Saturation means that the opamp output reaches its limits (power supply rail). The amplifier has left his linear range. Because of the very large dc gain and due to missing negative feedback), some tenth of µVolts between the inputs are enough to reach this state .
Question: Are you using dual or single supply for the opamp?
gerdomerdo
Joined Apr 2, 2021
9
I am using a single supply, I just want to know what is the voltahe at the pin 5 (+). (I know that it's greater than V-), but what is the exact value, so that we can have that voltage difference at the inputs.
LvW
Joined Jun 13, 2013
2,031
Voltage at pin 5 (+) under which condition? 7 Volts DC at R35 ?
BobTPH
Joined Jun 5, 2013
11,556
The voltage on pin 5 depends on the input voltage and the output voltage only. Write an expression for it in terms of those two voltages.
Bob
LvW
Joined Jun 13, 2013
2,031
Bob
Yes - that`s why I have asked for the input voltage .
Its nothing else than a case for superposition.
Danko
Joined Nov 22, 2017
2,176
Capacitors value is changed:
ADDED:
See how works ideal opamp.
Pay attention to R2 value:
R2=(R1/Vref)*(Vth-Vref) this formula is accurate for ideal opamp only. :(
Vth is high going threshold voltage.
gerdomerdo
Joined Apr 2, 2021
9
You have two separate voltage divider problems involving two resistors for each divider.
Are you saying you don't know how to do that?
I am asking about how to calculate the voltage at pin 5, if we consider that we don't know the output voltage we are having two unkown voltages. If it's simple to you explain it to me
38,540
The op amp acting as a comparator with positive feedback, so the output has two states, either positive saturation (plus input higher than the negative input) or negative saturation (plus input lower than the negative input).
So you calculate the input voltage difference for both conditions of the output, and see which one leads to the input voltage difference that is correct one for the two possible output voltages.
Make sense?
