Non-ideal and Simulable Components for Altium Simulations
sedatunalacak
Joined Oct 24, 2016
Hello , I use Altium to draw boards and LTSpice to simulate on it. However, I don't want to draw the same circuit 2 times anymore, hence I want to use Altium as simulator also. However I encountered some problems.
First one is capacitors-inductors-sources with internal resistances. I couldn't find such models that enable us to add internal resistances to components. I don't want to add series resistors as representatives of internal resistances of the components, because this means drawing the same circuit again which I want to avoid at first place.
Second problem is, I need libraries that includes both footprints and the necessary data for simulations (like simulable op-amps, capacitors with internal resistances etc.). Is there anywhere I can find such libraries?
