How to use an Ideal Diode Controller to Isolate 2 Signals and have one output?
Giosef
Joined Oct 13, 2023
Hi all,
I’ve been tasked with building a “shifter box” for a race car. The purpose is to manually place the transmission into neutral after a crash, since the car sometimes remains stuck in gear. To achieve this, I need to send a 14.5 V signal to the electronic shifter box, while maintaining a 3 V idle state under normal conditions.
I designed a comparator-based circuit to mimic the paddle shifter: when the button is pressed, the output switches from 3 V (idle) to 14.5 V. The problem is that when I tie the outputs together, they form a voltage divider, which throws off Vout.
I came across the idea of using Ideal Diode Controllers on each output line to isolate them, and then tying the outputs together. Would this approach work, or is there a better way to achieve this?
Thanks!
sghioto
Joined Dec 31, 2017
8,758
Pretty sure there's a better way.
Isn't there just one output line at 3 volts nominal then switching to 14.5 volts when needed?
Giosef
Joined Oct 13, 2023
Could you elaborate more on this? I agree there is a simpler way, I just can't quite figure out the logic for the 'simpler' way yet.
EDIT: Would something like a 2-position switch work? I think this would be much simpler lol
Ya’akov
Joined Jan 27, 2019
10,351
Welcome to AAC.
Given this is a safety device on a vehicle, it seems most prudent to use an automotive relay to do the switching.
The automotive environment is noisy and inhospitable, standard automotive relays are purpose built for it.
A you need is an SPDT (Single Pole Double Throw) with the input to the transmission on the common, 3V on the NC (Normally Closed) contact and 14.5V on the NO (Normally Open) contact. The crash condition would just have to energize the relay coil.
KeithWalker
Joined Jul 10, 2017
3,625
Welcome to AAC.
Would it not be safer to wire it in a fail-safe way where 14.5V is on the NC and 3V on the NO? Then in a crash mode, if the power to the relay coil is damaged, it will remain in crash mode.
Giosef
Joined Oct 13, 2023
Welcome to AAC.
Got it, thank you!
