Hello,Find the Q-points for the diodes in the four circuits in Fig. P3.68 using (a) the ideal diode
model and (b) the constant voltage drop model with Von =
What is a Q point?Find the Q-points for the diodes in the four circuits in Fig. P3.68 using (a) the ideal diode
The Q point is the quiescent operating point, also known as the DC bias point.What is a Q point?![]()
Presumably, they are only asking about one of them.You show only one circuit.
What about the other three?
Thanks.The Q point is the quiescent operating point, also known as the DC bias point.
I think a Q point for a diode is a little more unusual than for something like a transistor. This implies that there is some kind of analog action going on that depends on the voltage/current curve of the diode. Once the diode is 'biased' it will have a certain dynamic resistance and that would be tantamount to understanding how the circuit operates in the specific application.What is a Q point?![]()
How is that any more unusual than for a transistor, which is the exact same things -- the dynamic behavior about the operating point depends on the operating point in both cases.I think a Q point for a diode is a little more unusual than for something like a transistor. This implies that there is some kind of analog action going on that depends on the voltage/current curve of the diode. Once the diode is 'biased' it will have a certain dynamic resistance and that would be tantamount to understanding how the circuit operates in the specific application.
Hello there,How is that any more unusual than for a transistor, which is the exact same things -- the dynamic behavior about the operating point depends on the operating point in both cases.
Hello again,If "unusual" is based on diodes being used more in switching circuits than in small-signal operation, then transistors operated in small-signal are probably unusual, too, since my guess is that they are used in switching applications far more often, as well -- and that's not even considering MOS transistors that are overwhelmingly used as switches, especially if you include integrated transistor circuits.
But it's really neither here nor there. The Q-point of neither is "unusual" since the Q-point doesn't care how the device is being used. It is simply the quiescent operating point of the device in that circuit, whether it be an amplifier, a receiver, a rectifier, or whatever.
The first question is what the textbook means by an ideal diode model. It can be either of the following:Find the Q-points for the diodes in the four circuits in Fig. P3.68 using (a) the ideal diode
The "ideal diode" model virtually always refers to (1) and on the few occasions when it doesn't, almost always refers to what is more commonly known as the constant-voltage drop model. In this case, the latter is ruled out in this case because the question explicitly asks for that as the second part of the question.The first question is what the textbook means by an ideal diode model. It can be either of the following:
1. The diode acts like an open circuit when it is reverse biased and a a short circuit when it is forward biased.
2. The diode is characterized by the Shockley equation.
In case 1 the problem is really simple and you should be able to solve it easily.
In case 2 you have to solve a system containing nonlinear equations which can probably only be done numerically.
Please show us your best attempt.
Hi again,I don't see what the application has to do with it. Every diode has an operating point in every circuit, just as every transistor has an operating point in every circuit. If it seems unusual to you that diodes have an operating point, fine.
Hello,Whether or not it's important to know what the operating point is is completely beside the point. That has no effect on the fact that it HAS an operating point.
And I consider the operating point of a rectifier diode in nearly any circuit I design, since the operating point provides the information needed to determine whether the diode I am considering is adequate. If the operating point when forward biased is going to be about 1 V at 10 A, there are lots of diodes I would not consider because they are not suitable for use at that operating point.
| Thread starter | Similar threads | Forum | Replies | Date |
| V | How to find CPU Load for microcontrollers | Microcontrollers | 14 | |
How do you trace/find underground broken wires? | Off-Topic | 27 | |
cannot find the surveillance camera I want :-( | Off-Topic | 11 | |
| U | Find the resistance between 2 points | Homework Help | 13 | |
algorithm to find the mid points of datas. | Programming & Languages | 16 |
