Noise on Bluetooth reciever -> Ground loop?
DefinitivVair0
Joined Dec 11, 2024
Hi there,
I recently got an old GoldStar GSM-6330 and wanted to add an internal Bluetooth-receiver to it, without sacrificing any of the existing functionality. I decided for some cheap Bluetooth receiver board.
You can see on this image, how I wired everything. (I stole the +-12V from the phonograph power and tied the LGR 3pin output of the receiver to the AUX-input so I can still use the RCA input like normal. -> I also tried plugging the 3pin phonograph audio cable into it; same result.)
Sadly once I connect power and audio to the receiver I get some LF-noise and some "beeping" but can still hear the transmitted audio through the noise. Once I power the module from USB or a second power supply, the noise disappears. I looked around and found a video talking about the exact same problem, saying that its a ground loop and that you can fix it with an DC/DC isolated converter. But (i would have to look again, I don't really remember right now) the power consumption of the module is exceeding the rating of every (SMT) isolated converter I could find.
So my question is, if a ground loop is the problem, and if yes, how can I fix it?
Also, I can supply audio clips, images of the wiring / PCBs / power supply or whatever. Just ask if you need anything to help me out.
Thanks in advance :D
DickCappels
Joined Aug 21, 2008
10,660
If you want to avoid the isolated power supply, you might get lucky and find an audio transformer of a suitable high impedance.
Before undertaking any major changes, you might want to try using a battery pack and a monolithic (linear) regulator as your isolated power supply. If that doesn't fix it you're looking in the wrong place.
DefinitivVair0
Joined Dec 11, 2024
I did not try a battery pack but I tried using a random 26V 0.5A charging cable to get power from somewhere else than the built in power supply of the GSM-6330. This worked perfectly without any noise which leads me to believe, that it has something to do with the build-in power supply and a ground loop seems logical.
DefinitivVair0
Joined Dec 11, 2024
