Noise from Bluetooth speaker
kalemaxon89
Joined Oct 12, 2022
389
The speaker in question was paid for a few euros online:
and has this noise during playback (often starting just a few seconds after normal use):
https://jmp.sh/qB5qZXsU
Where can this noise come from?
From the antenna?
From the power supply? (battery)
Maybe Bluetooth operates on the 2.4Ghz band and can interfere with home wifi?
Is there any way to remove it?
BobTPH
Joined Jun 5, 2013
11,662
Does you phone send the same audio to a different BT speaker correctly?
Does a different phone work correctly with this speaker?
Does a different music source on this phone work correctly?
There is some component misbehaving. You need to find out which one. It is not RF interference. That would cause an entirely different symptom.
