Why is there so much noise on my bluetooth speaker setup?
kmeyer
Joined Oct 10, 2019
10
With this wiring the noise is brutal. However, if I remove the power to the Bluetooth module from the l7805cv, and instead use the microusb power socket on the bt module the noise goes away. Are my connections to blame? Is it the voltage regulator?
Any advice would be appreciated.
Thanks.
https://streamable.com/o8lpcv
KeithWalker
Joined Jul 10, 2017
3,613
You don't give us very many clues to help you. The picture conveys nothing to me and my crystal ball is a little foggy tonight.
Give us the details of what modules and power supplies you are using, what your signal source is and a diagram of the wiring and we may be able to help.
Audioguru again
Joined Oct 21, 2019
6,826
ALL audio amplifiers use shielded audio input cables. You use ordinary wires that are antennas that pickup interference.
What is the amplifier part number?
kmeyer
Joined Oct 10, 2019
10
apologies, hope this helps....
KeithWalker
Joined Jul 10, 2017
3,613
That helps a lot. What kind of noise are you getting? is it a low frequency hum or a sharp crackling noise? What is supplying the 12VDC? Is it a wallwart? What current is it rated for? I suspect that it is the source of the noise. Try connecting a 100 uF 25V electrolytic capacitor across the 12V (observe the polarity) and see if it makes a difference.
kmeyer
Joined Oct 10, 2019
10
That helps a lot. What is supplying the 12VDC? Is it a wallwart? What current is it rated for? I suspect that it is the source of the noise. Try connecting a 100 uF 25V electrolytic capacitor across the 12V (observe the polarity) and see if it makes a difference.
i googled wallwart. yes, it's a wallwart
What do you recommend as a power supply?
kmeyer
Joined Oct 10, 2019
10
Kind of a crackling hum. You can hear the noise for yourself. Here's a recording from my original post: https://streamable.com/o8lpcv
Audioguru again
Joined Oct 21, 2019
6,826
I think the noise is the switching of the power supply. Use a linear power supply instead and use shielded audio input cables.
The 5V regulator feeding the Bluetooth receiver might not properly filter noise from the power supply.
With a 12V supply, the class-D TPA3110 amplifier produces about 8W per channel into 8 ohms speakers at low distortion, or 12W per channel into 4 ohms speakers.
kmeyer
Joined Oct 10, 2019
10
Also, are you using the recommended capacitors for decoupling on the LM7805?
Bertus
I've ordered some caps. I'll need to research how to solder up what's in that circuit diagram.
Thanks everyone.
