Newbie - RS Logix programming help (Homework Assignment)
999Bankie
Joined Jan 23, 2017
Hi. I just signed up for a PLC/HMI programming course at my local college. The PLC work is in RS Logix Emulate 500. The PLC theory is more 'advanced' as opposed to the 'basics' that I'm familiar with.
The assignments are to do with Data Manipulation (Timers, up/down counters etc).
I've attached my homework assignment.
Can anyone shed some light as to what timers, counters (up/down), interlocks, permissives are required ?
Thank you in advance.
MaxHeadRoom
Joined Jul 18, 2013
30,658
First you need the RSlogix programming manual, this is explain all the different function of timers counters etc.
What is the object of the bottom example ladder shown? As a start?
Max.
999Bankie
Joined Jan 23, 2017
Hi. Thank you for your reply.
The Start/stop ladder logic circuit (page 3) is what we were told to use to 'initiate' the operation.
MaxHeadRoom
Joined Jul 18, 2013
30,658
That is what the question refers to as a 'Permissive' or start/stop.
It just shows a timer on delay with .01 sec interval and 200 preset value, and automatically resets itself once it times out and repeats, as per the description.
It would appear that for assign: 1 you would need 2 timers and a counter.
I am more familiar with Mitsubishi PLC's.
Max.
999Bankie
Joined Jan 23, 2017
Max.
Thanks for your input.
