Newbie, I broke my power supply!
Walt_Lankor
Joined Apr 15, 2022
17
I fired up my new power supply, a very basic model, Rapid 85-1901, shorted out the outputs to set the limiting current, the supply made a humming noise and died, this blew the 5amp fuse. Now it blows 5 amp fuses directly on being switched on with no output leads in place.
I think I followed the proper procedure for setting the current, I can only assume I somehow drew too much current and blew the fuse and something internally too. I did use a pair of probe leads joined with a crock lead to short the outputs, though I find it hard to believe this would drop enough voltage to pull meaningful current, but I have been wrong before.
I would be pleased if anyone could help out, I am also interested in trying to repair it and any clues where to start on the board would be appreciated.
Many thanks
38,948
You set the current properly.
Apparently the supply was not well enough designed to tolerate the short circuit.
Do you have a schematic of the supply?
Difficult to troubleshoot without that.
Boggart
Joined Jan 31, 2022
82
That supply has been discontinued by Rapid, I wonder why...
I've been using a general purpose 0-30V, 5A PS as one of my benchtop supplies for many years, the same (looks the same at least) is tagged as a PS-3005D under the Wavecom and other brands. It has been excellent for the last 10 years...
Walt_Lankor
Joined Apr 15, 2022
17
Many thanks for the reply, I don't as yet have a schematic but I will be looking for one. I did start on reverse engineering it but it is quite complex
Walt_Lankor
Joined Apr 15, 2022
17
Walt_Lankor
Joined Apr 15, 2022
17
Welcome to AAC!
Is it still under warranty?
Hi many thanks for the support, no the supply came from a friend's attic I think it has been sat for some time. I'm more curious about the possibility of a fix for the interest and to see if I made a mistake with it.
Walt_Lankor
Joined Apr 15, 2022
17
Hi, many thanks for the support. Indeed the design looks to be badge-engineered by quite a few vendors, not sure if there were any major updates that were needed.
Walt_Lankor
Joined Apr 15, 2022
17
Many thanks
Thanks, everyone for the prompt comments, always nice to get some support in a new area
much appreciated
dl324
Joined Mar 30, 2015
18,523
Open it up and do a visual inspection to see if anything is noticeably damaged. In any case, you're going to need to trace the circuit and create a schematic before anyone will be able to help you. If something is damaged, that would give you a good starting point.
SamR
Joined Mar 19, 2019
5,542
Probably because it was a poorly made Switch Mode PSU? I have 3 of these now. Nothing fancy but 30VDC/5A linear designed with both Voltage and Current limiting if desired. Settable to 1mV & 1mA. Solidly built and not a bad deal for the 85USD price. Maybe even cheaper elsewhere. So far, I haven't found a need for uV or uA level power supplies.
Walt_Lankor
Joined Apr 15, 2022
17
Hi, many thanks for your comments, there are no clear sign of any issues internally, no burning or blown caps etc
I did find the manual and schematic
https://www.manualslib.com/manual/897687/Manson-Engineering-Industrial-Nrp-3630.html?page=8#manual
The CC setting process is specified as set 3v and then short the output to set the current limit. I had voltage the 12v I think.
Does this sound like the error that may have caused the failure?
Walt_Lankor
Joined Apr 15, 2022
17
Next time you want to set a current, turn the current all the way down before shorting the leads. Then turn it up slowly.
Bob
Many thanks for the comment, please see my other reply with respect to the CC procedure "with a 3v preset".
Do you think think the non-zero current before shorting is a"sensible precaution" or a "must" to prevent a failure?
Thanks again
Dodgydave
Joined Jun 22, 2012
11,395
This is not your psu , yours is a switchmode type, using a TL494 chip.
Measure the voltage at pins 14/7 to see if it's working.
Can you post any pictures of the pcb?
Walt_Lankor
Joined Apr 15, 2022
17
Many thanks
Attached is what I believe to be the correct schematic for my supply 20V 5A (Manson NSP2050) the board I think is common to the (Manson NRP 3630) 36V 3A, as my board is marked as the 3630. I have the manuals for both the 2050 and 3630 but they both have the same sill screen diagram in them (see attached)
I can upload pics of the board if needed, however this thread:
https://www.eevblog.com/forum/repair/smps-bench-supply-keeps-on-popping-output-rectifiers/
is for the same supply and has good images and I think has some useful comments too
Many thanks
Walt_Lankor
Joined Apr 15, 2022
17
Thanks again, I forgot about your comment on the pinout voltages, currently the supply blows the fuse when plugged in and I have yet to try and isolate the mainboard from the outputs.
thanks
