New Batteries For EV's
MrAl
Joined Jun 17, 2014
13,726
Yeah I saw that ship tragedy, nasty.
On the lighter side of life, Toyota supposedly came out with a 900 mile solid state battery for their cars. Supposed to happen 'soon'.
Ian0
Joined Aug 7, 2020
13,158
Isn't any battery which stores that amount of energy in that volume going to be dangerous?
At least the superconductor is should be cheap - it's mainly lead phosphate
MrAl
Joined Jun 17, 2014
13,726
I am not sure what you are saying, it seems you are mixing batteries with superconductors?
I was not addressing your post i was just mentioning that there may be new batteries for EV cars.
Is the battery dangerous? Well, it is solid state, so I think it is safer than batteries that are not solid state. I don't have all the facts yet though so I'm still a little in the dark too. They didn't give a release date yet either. It's supposed to be a breakthrough in EV powering technology, or simply battery storage.
Ian0
Joined Aug 7, 2020
13,158
Well, I wasn't deliberately. I commented on your solid state battery comment, along with a further comment on the superconductor.
But it's not such a daft thing to mix - could superconducting cell interconnects reduce battery heating?
I'll shut up and go to bed.
MrAl
Joined Jun 17, 2014
13,726
No that's ok I just thought that the two subjects are usually discussed in a mutually exclusive way, but being able to wire them together with zero Ohm wires would be really good too, as well as wiring to the motor. Heavy current drops larger voltage with regular wire, and I could imagine how high the current is for these EV motors.
https://www.reuters.com/business/au...production-by-year-michigan-plant-2023-10-17/
GM delays EV truck production at Michigan plant by year
General Motors Co (GM.N) said on Tuesday it will delay production of electric pickup trucks at its plant in Michigan's Orion Township by a year as the No. 1 U.S. automaker grapples with flattening demand for electric vehicle.
The move is the latest sign that electric vehicle production and demand may not be as strong as forecast. GM had been set to begin production of the electric Chevrolet Silverado and GMC Sierra in late 2024 at the suburban Detroit plant. The company said the plan now is to start it in late 2025.
GM said the change was being made "to better manage capital investment while aligning with evolving EV demand" but said the move does not impact its battery plant plans. GM said in July battery production at the Ultium joint venture plant Ohio has been hampered because "our automation equipment supplier is struggling with delivery issues."
Audioguru again
Joined Oct 21, 2019
6,826
We do not have any of those cheap and tiny Chinese EV cars YET!
A photo of a parking lot in China shows a few of their EV cars and a couple of EV bus's on fire.
What does the connector for a 1MW charger look like? That's 1000V at 1000A. How can the socket tubes be small enough to stop the general public sticking their fingers in them?
Make it big so they on stick the fingers in once when powered. :eek:
https://www.charin.global/media/pag...3/whitepaper_megawatt_charging_system_1.0.pdf
III. HV Touch Safety
High voltage (HV) touch safety is a measure intended to prevent living objects from contacting
conductive paths that may have a high voltage and/or high temperature. Globally many governmental
bodies require IPXXB for high voltage connections that are outside of a passenger compartment. IPXXB is
defined by IEC 60529 and is intended to prevent a defined “finger” from contacting any hazard surface.
MCS never intends to have any high voltage exposure when the connector and inlet are not mated. Based
upon the experience with the CCS standards development and the lessons learned toward broader
adoption of the CCS interface in regions with other guidelines related to touch-safety protections, the
MCS design followed these learnings and is constructed to provide IPXXB level of touch safety.
https://www.gt-engineering.it/en/in...rotection-from-direct-contacts-ipxxb-or-ip2x/
