AlbertHall
- Joined Jun 4, 2014
- 12,652
R1 is fitted. About 33V across 2k2 means there is a load of 15mA across the bridge output.So have you tried adding a load to U5's output to see if that makes a difference?
Hello AlbertThose are correct if you still have the 330Ω across the output so I am out of ideas as to why the output voltage is too high.
Problem Solved!!!R1 is fitted. About 33V across 2k2 means there is a load of 15mA across the bridge output.
