Negative and Positive Bridge Rectifier Circuits
Status
Not open for further replies.
Lainya
Joined Apr 13, 2008
4
Can anyone explain to me why I would get a smaller DC reading across the load of my circuit than the predicted value even when the rectified peak voltage is almost the same as my predicted value? See revised thread
rubberman
Joined Apr 13, 2008
1
There is no much information there. Has the load of your ciurcuit the same value as the input load of your probe or measurement device?
JoeJester
Joined Apr 26, 2005
4,390
Smaller is a relative term ... how much smaller? 12 to 11 is smaller ... but certainly within 10% of the desired (12).
Post your circuit and describe or post the load.
Wendy
Joined Mar 24, 2008
23,848
Their right, need input.
A likely cause is if you're using a transformer it is loading down a bit, and coming out with slightly less AC under load.
Status
