So im trying to make a combinational lock in proteus. One of the issue i've come across is one of my button which is labelled "reset" output high even if its not press but when I connect a logic probe to the line, the cable becomes normal. The second issue is there is a sequence detector that output 1 when there is 1111 input sequence, it was working as intended but when I add the button labeled reset, the said detector output 1 when the input sequence is 111 and 1111. Im also open for suggestion to improve my project, thank you![Screenshot 2023-12-11 190839.png Screenshot 2023-12-11 190839.png](https://forum.allaboutcircuits.com/data/attachments/297/297399-0041dafd80d775cbefd03351e13d99ac.jpg)
