Hi Benard I have done the instruction you mentioned.
1.Lift one end of D2 & adjust BBR1 to 10 V, are LEDs on? Yes LEDs are on
2.Lift D1 & adjust BR1 to 9.5 V, are LEDs on? No LEDs turn off
3.Use RSP, 10k pot as an adjustable V supply. Lift R27-2 & connect it to RSP-2. Adjust RSP-2 to 11.5V, or to battery spec. for minimum discharge V. D-7 should be low. What does RSP mean? Anyway I assume is to use additional VR and adjust pin 2 to 11.5V then connect to R27 pin 2.
4.Lower R28-2 slowly until D-7 goes high. Battery is now disconnected from BR1 & Q4 & will remain disconnected until battery is charged to about 12.6V. I tuned R28 but it does not affect D7 Voltage.
So now I am pretty much stuck here and could not proceed further. I check on the B1(charging battery), the voltage is draining slow instead of charging.
