Need help reducing the power on main voltage LED light
cdebrebisson
Joined May 5, 2024
17
I bought a LED light which claims to be 30W.
It is powered from the main 220V.
Attached is a picture of the power system which seems to bring the 220V to what seems like 2x100V channels. (as measured with a multimeter between the middle and side wires).
What I need to do is reduce the LED brightness by a factor of 10 or 100 (I want to use it to callibrate a telescope camera, which are hyper senstive).
What would be the best way to do it?
I first thought about adding a resistor in series, but I have no clue what spec to use for the resistor.
I also thought that the voltage regujlators probably have a "tunning" resistor and that "simply" swapping out a small smt component might reduce the overall power, but I have no clue which one it will be and by what I need to change it... And that is befre talking about the dificulty of doing the soldering!
Can you guys help me find the best/easiest sollution?
Thanks,
Cyrille
Sensacell
Joined Jun 19, 2012
3,789
Buy neutral density gel filter and wrap the lamp.
You will find fiddling with the electronics yields poor results- color temperature shifts, etc.
So easy.
Pyrex
Joined Feb 16, 2022
556
Your photo isn't very high quality, so it's hard to tell which resistors set the current through the LEDs. The resistors that determine the current are small, usually up to 10 ohms or less. It could be that it's resistor R1, R1A and R2, R2A. I'm guessing that R1 and R1A are connected in parallel, and also R2 and R2A .Insert another resistor, slightly higher in resistance, and you'll see if the LED brightness has decreased
cdebrebisson
Joined May 5, 2024
17
Thanks,
I take it cutting the "middle" wire, adding a resistor in series there is not a good idea?
Note that in typical use, the light will be turned on for around 1 minute per night..
Color temperature is not an issue also.
I was able to take these 2 slightly better pictures of these resistors.
Cyrille
Danko
Joined Nov 22, 2017
2,238
Сurrent of LEDs is defined by value of parallel connected feedback resistors R1 and R1A (R2 and R2A).
Bigger value - lower current - bright reduced.
ADDED:
To @Pyrex : Sorry, i did not notice your post #3.
Pyrex
Joined Feb 16, 2022
556
Thanks,
Cyrille
sure you can add a resistor in series with those two
Ya’akov
Joined Jan 27, 2019
10,308
Try sending the photo to Big Clive (YouTube). He has a hobby of LED lighting and enjoys modifying the PS circuits to reduce the output to the LEDs. Seriously.
The fastest way to get his attention would be to pay the two bucks to join his Patreon and message him there.
28,395
Since I don't see any circuit schematic of that PCB, nor any information as to the "30 watt lamp", nor about the connections, providing detailed advice is a serious challenge.
What I think is that there are actually two LED light sources that we are not shown or told about.
IF the TS is able to accurately measure the voltage from the center positive terminal to each of the two side(negative) terminals, then we can guess the current on each side, and suggest a suitable series resistor to add to reduce the light intensity.
The data in the link attached to post #6 was quite helpful. BUT what I see of that circuit tells me that adjusting it by changing a resistor will not be as simple as we would like it to be.
A description of the LEDs portion of the light package assembly will serve to help with suggestions as to how to make changes.
AND I am wondering what sort of light would be used " to callibrate a telescope camera, which are hyper senstive). "
My guess is a lot less than 30 watts.
wayneh
Joined Sep 9, 2010
18,170
Buy a different, dimmable LED with a much lower output. You're trying to swat a mosquito with a sledge hammer. Just start with the right tool for the job and save yourself the trouble.
MikeA
Joined Jan 20, 2013
450
Highly doubt the circuit is "tunable" using resistors to achieve 10x less output. Let alone 100x.
Are you really sure it's 100V DC and not something coming from the mains side?
You could spend a few dollars Aliexpress to get a DC PWM controller with enough voltage input.
cdebrebisson
Joined May 5, 2024
17
Here is a picture of the whole light.
220V comes in, goes through that circuitry and comes out using 3 wires, something that looks like a common and 2 continious voltage output.
Measuring from the common to each of the 2 other pins is 100V. Kind of scary when the space between them is so small!
Tunning the circuit changing some SMT resistor is most likely the best technical solution...
But might not be the more practical for someone who is not a soldering iron wizard (as is my case)!
This is why I was more interested in a solution using an inline resistor on the common wire, much easier to do (cut wire, solder resistor, resin or other around to hold it in place.
Of course neutral mask on the output would work, but the light is more than 30cm in diameter so I would need to perfectly but join the sheet (which are 297mm) which would be hard to do...
> AND I am wondering what sort of light would be used " to callibrate a telescope camera, which are hyper senstive)." my guess is less than 30W
Its about timing more than anything else.
We can reduce exposure to around 0.1milli second, but we do not want to saturate (y=usually we want around 60% of max)...
30W is a lot. 3W would be much nicer :)
Thanks for your guys help..
Cyrille
PS: of course they are available commercial solutils, but for >200€ while a ceiling lamp is 10! Tinkerers go to tinker :)
BobTPH
Joined Jun 5, 2013
11,660
Are we talking about a bulb that actually consumes 30W or one that is equivalent to a 30W incandescent bulb? If the former, that us one powerful LED bulb.
wayneh
Joined Sep 9, 2010
18,170
The photo in #15 clearly shows the strip of LED chips around the perimeter. They're almost certainly in series but there are probably two strips with staggered LEDs of the two color extremes, to provide the adjustable color range. I assume that's what the 3 wires are for, one common and two for the different colors.
Dimming might well be accomplished by PWM at a frequency we can't see, for instance 60kHz. I have no idea how your equipment works but it might be able to "see" on-off flashing at higher frequencies than we can see. Just because it's advertised as not flickering doesn't mean it's continuous.
28,395
IF the driver is CC then after the point where the full compliance voltage is reached, it will startto dim.
but I see no way that light could be used for "calibration". Evidently I don't undserstand what sort of calibration the TS wants to achieve.
