When i plug my headset in the back of my pc the audio is really soft and when i plug it in the top it is normal, is there any way i could fix the audio coming out the back?
If you mean the audio volume is low is understandable. The green colored jack is not meant for headphones.It's the audio out that is soft
BertusConnecting a low-impedance load such as a loudspeaker (usually 4 to 8 Ω) to a line out will essentially short circuit the output circuit. Such loads are around 1/1000 the impedance a line out is designed to drive, so the line out is usually not designed to source the current that would be drawn by a 4 to 8 ohm load at normal line out signal voltages. The result will be very weak sound from the speaker and possibly a damaged line out circuit.
Just get a set of "computer speakers" they have the built in amp designed to be plugged into the line-out jack and a headphone jack is usually included.What's a good not to expensive audio amp?
No. That is not designed to drive headphones.Is this one good?
If a package is to translate a digital signal then IT IS NOT an amplifier. And why would anybody want such a piece of junk???Most headphone amps these days are for digitial DAC and not analog line out. Build one with an lm386 with adjustable gain. Or buy a module from AliExpress.
FIFINE N6 Headphone Amplifier with Stereo Output and Individual Volume | FIFINE MICROPHONE
Also sold on Amazon for more money!
How much customer support can you get from amazon???? Price and shipping weight, and possibly package size. Maybe.It not only translates the USB digital signal, but they also have a headphone pre-amp and amp as well. Just what piece of junk are you referring to? Headphone amplifiers hold quite a niche in audio equipment sales. Products sold by Amazon are also sold in high end audio catalogs and stores.
