Need guidance on this homework problem
wolfsquadron3
Joined Feb 23, 2020
15
I have a problem in my ET212 class that I truly have no idea on where to start, I have the circuit design, but am clueless when it comes to the values that I need to use. I am not asking for answers, mainly just guidance on where I am supposed to start, or the steps i need to do to find my answers.
Project details are 250mV peak input voltage, 20-20k Hz range, 8.4W power output 8 ohm load. I just have no idea where to start with analyzing and figuring out what capacitors or resistors I need to use. I know that I (probably) need to start with getting the voltage gain set for each transistor, but the darlington pair i dont understand well. The circuit design is below, any help is greatly appreciated. The 1k ohm and 1uF values are placeholders, as well as the VCC value.
BobTPH
Joined Jun 5, 2013
11,664
Where did you get that circuit? Was it part of the assignment?
You say you don’t know what values to use, but they are all on the schematic. Do you think you can change the values and meet the requirements of the assignment?
How about this for starters: What voltage swing, peak to peak, is required to get 8.4W in an 8 Ohm speaker?
Bob
wolfsquadron3
Joined Feb 23, 2020
15
Bob
Hey
Not entirely sure what voltage swing is, and yes it is from an assignment, we need to figure out the values to get the needed output power with the supplied input voltage. The resistor and capacitor values in the circuit right now are just place holders to design the circuit. Need to find the actual values needed.
BobTPH
Joined Jun 5, 2013
11,664
Well , your professor is a dolt, because a curcuit like that cannot practically produce 8.4W.
By voltage swing, I mean the peak to peak voltage of a sine wave that would produce the 8.4W power. You clearly know this since you correctly calculated the gain.
Bob
WBahn
Joined Mar 31, 2012
33,283
I haven't run any numbers to see how feasible it is, but practicality probably doesn't play into it. It's a design exercise covering specific topics and is further limited in that it can't utilize concepts from topics to be covered later. It's very likely that one of the points of the assignment is to highlight the issues that would make using this approach impractical specifically as a segue into later topics to motivate more practical approaches.
This of the typical progression of simpler topics -- people learn resistive voltage dividers early on and it isn't uncommon to have an exercise in which such a divider is used as a power supply for some circuit, the primary intent being to drive home why resistive voltage dividers make lousy power supplies. This is then often followed by zener diode based supplies and again an exercise is used to illustrate that they are only suitable as supplies in pretty narrow situations. Then later various forms of linear regulators get introduced. The notion of switched-mode power supplies is a topic that doesn't come along until much, much later. I wouldn't consider the professor that has the design exercise involving a resistive voltage divider to be a dolt because they didn't use a SMPS.
wolfsquadron3
Joined Feb 23, 2020
15
Bob
The needed input voltage and output power were choosable, the options were 100, 150, and 250mV for input voltage and 3.2 W, 5.6 W, 7.1 W, 8.4 W, 11.5 W, and 16.3 W for the output power. It is a group project and we each have to make a amplifier with different selections. I just chose the 8.4W and 250mV randomly.
WBahn
Joined Mar 31, 2012
33,283
Are you going to actually build, test, and demonstrate your amplifier, or is it just design and simulate?
WBahn
Joined Mar 31, 2012
33,283
Design and simulate only
That's what I suspected and it's a real shame. You would have learned SO much more if you actually had to build it. Smoking transistors is a much better teacher than a number displayed on a schematic as the result of a simulation.
wolfsquadron3
Joined Feb 23, 2020
15
This is actually the final project of this course, and it is an online class as well. The hardware portion is very limited sadly. Currently I am trying to figure out the middle stage of the amp, i think I have gotten the power amplifier part finished(hopefully) and just need the other two voltage amplifier portions. If you want to glance at my Power amp portion and see if anything sticks out to you as wrong, that would be great. The main things that I am not sure about are the input voltage to this part of the circuit and the value of C1.
Edit: I forgot to say that I have decided to change the needed output power to be 3.2W instead of the original 8.4.
Audioguru again
Joined Oct 21, 2019
6,826
Since the student knows nothing about the voltage swing (peak-to-peak) of an audio amplifier and knows nothing about how to design a simple single transistor circuit and connect them in series then he can't do this project until he is taught about electronics.
Another homework assignment where the teacher does not teach anything but expects the students to find a forum where an expert will do it (for free?) for the students.
Oh, now the output Darlington emitter-follower is shown with an 8V supply and its base is biased at 4V. Then its emitter cannot go lower than about 4V minus its 1.3V base-emitter voltage drop which is 2.7V peak. Then its RMS output is voltage is 2.7V x 0.707= 1.91V RMS. Then the maximum output power in the 8 ohm speaker is 1.91V squared/8= 0.46W.
Its "peak power" is 0.92W and its extremely distorted squarewave power (phoney power) is 1.84W.
But he wants 3.2W that ain't gonna happen. 3.2W in an 8 ohm speaker is 5.2V RMS which is 14.7V peak-to-peak. Then the supply for this Darlington transistor must be 1.3V higher which is 16V minimum.
Oh, I forgot. The 8 ohm resistor R3 will not produce enough negative voltage swing so the supply must be 14.7V/4= about 3.7V higher which is 19.7V minimum.
