Need generic gate array (not FPGA, if possible)
schmitt trigger
Joined Jul 12, 2010
2,211
TC17G005AF-0048 is an ASIC for a very particular functionality.
The 74ALS832 is a hex 2-input driver.
Where did you get the idea that the second device could remotely replace the first?
drjohsmith
Joined Dec 13, 2021
1,647
The position of the TC17G005AF-0048 in the shown schematic is important: between the DF and DAC. Connected by three I2S lines. Normally, such an arrangement means some sort of "re-clocking". But that is often done using 74 logic chips:
https://www.diyaudio.com/community/threads/asynchronous-dac-reclocker-circuits.325391/
There is a partial datasheet of "TC17G005" here:
https://tvsat.com.pl/PDF/T/TC17Gxx_tos.pdf
This is an ASIC
ASICs are general purpose devices, as are FPGAs and CPLD's
They are programmed,
Its like having a ARM CPU,
its general purpose,
depending upon the programming,
Unless you have the programming, the knowledge is just about useless.
BobTPH
Joined Jun 5, 2013
11,637
You are the one who said you needed a generic gate array. That does refer to a chip that needs programming. An asic might or might not need programming.
What you need s a replacement for the part in that schematic, and it might well be impossible to find because it is proprietary part made for the manufacturer and not available to anyone else.
