MisterBill2
- Joined Jan 23, 2018
- 28,636
OK, much more reasonable and totally not what I had guessed. I have a caution, which is that the circuit in post #10 will draw a small constant standby current, so the batteries would eventually be drained.
With the magnet in place the current drain is 150ua.I have a caution, which is that the circuit in post #10 will draw a small constant standby current, so the batteries would eventually be drained.
There is expected battery charge life so there will be charging AND OR batt. replacements on site to play with.With the magnet in place the current drain is 150ua.
To get a price on a PCB production you usually need to have a layout to be produced. Creating an actual layout pattern from a circuit is not a trivial task, even with an auto-router helping. AND, even with an auto-router you still need to verify that the components you want to use will fit the layout it generates.That`s Great! Thank You for the link.
What do I need to send them to get a quote? The schematic from above and specify SMD and the board width?
For something that size, I can`t even try to draw a small enough circuit trace with my hand tremors. I need to find somehow to get the schematic to a company who can make the circuit board from that and them know it is for SMD parts, IF that is possible.Or you could draw your design with a sharpie on a copper clad board etch one yourself. That's how I got started when I was beginning in electronics as a young teen.
Exactly how many parts will need to be on the pc board inside the cylinder?For something that size, I can`t even try to draw a small enough circuit trace with my hand tremors. I need to find somehow to get the schematic to a company who can make the circuit board from that and them know it is for SMD parts, IF that is possible.
Hello, every part in the schematic above goes inside the cylinder. The circuit board can not be wider than 15mm with parts mounted on it. It`s length of course be longer than width. The ONLY parts at one end are the variable pot and the Magnetic Reed switch. I planned on having the Reed switch half mounted on the board and the other have as a plug for the main Lipo 3.7v battery to plug into.Exactly how many parts will need to be on the pc board inside the cylinder?
What about the potentiometer?
I just joined the site and sent them a few questions, they are NOT on line to reply right now. I await their reply.Many of us here use JLCPCB.
They currently charge only $2 for 5 small PCBs and about $25 shipping to the US. The quality is quite good.
I`am stunned. Thank You for your Time / Help.
Wow, Thank You for your offer. From what little I know about this stuff. I am looking to fit this board with ALL it parts mounted on it in the cylinder : 15mm wide by what ever length makes it easy to fit / work with mounting the parts onto it. As for the I.C 1--- LMC555. I do mot know it`s size specs. Can I ask you to research one for that info. then send me the link to its dealer, I will order as many as I need.If this is a final prototype design, give me the dimensions of the board and the footprint (IC package) of IC1.
I can etch one proto board at no cost.
