ne555 timer
kcx
Joined Mar 10, 2013
2
hello guys, I am doing a project using ne555, 4026 and 7-segment display. I am wondering how to fixed the running time using ne555. The circuit I tried is keep running from 0 to 99(non-stop).So, I want to fixed it to 60s(I am when it run until 60 it will stop). Anyone can help me solve this problem.:confused:
Dodgydave
Joined Jun 22, 2012
11,395
Can you post your circuit so we can assist you further please?
If your using the CD4026 then you need to put a high signal on pin 2 when the count is at 60, to inhibit further clocking.
35,180
Consider replacing the NE555 with TLC555 or LMC555. These are CMOS versions, require less current and put less noise on the supply lines.
