I wired the NE555 timer as an astable multi vibrator and have this output, is this the best I can expect as a square wave from this chip, or is there a fault? I have checked the calibration of my probe and it's fine.
Schematic? Picture of the output?I wired the NE555 timer as an astable multi vibrator and have this output
Show the circuit and an image of the output.I wired the NE555 timer as an astable multi vibrator and have this output, is this the best I can expect as a square wave from this chip, or is there a fault? I have checked the calibration of my probe and it's fine.
How can anyone possibly tell you if "this output" is the best you can expect if you won't show us what "this output" looks like?I wired the NE555 timer as an astable multi vibrator and have this output, is this the best I can expect as a square wave from this chip, or is there a fault? I have checked the calibration of my probe and it's fine.
Sorry i forgot to attatch the schematic.I wired the NE555 timer as an astable multi vibrator and have this output, is this the best I can expect as a square wave from this chip, or is there a fault? I have checked the calibration of my probe and it's fine.
That doesn't help much. You don't tell us what values you used for the various components, what frequency you are trying to achieve, and -- most importantly -- an image of the waveform you are actually seeing, since you are asking us to tell you if that waveform is reasonable.Sorry i forgot to attatch the schematic.
I'm glad you got it working. If you tell us what values you used before -- and perhaps what kind of capacitor -- and what you changed it to, we might be able to give you some idea of why you see such a difference. That might help you in the future avoid a similar problem. And, again, an image of the actual waveform, preferably before and after, would really help that along.I changed the timing capacitor and it cleaned up nicely.
thanks for all your replies people.
As I said before, the schematic does us very little good. You asked if the waveform you are seeing is the best that you can expect. How does the generic schematic, without even any component values, have ANY possibility of giving us enough information to evaluate whether the waveform you are seeing is reasonable or not?I enclosed the schematic in post #5
That's useless without component values and a picture of the output.Sorry i forgot to attatch the schematic.
Changing the cap value also changes the timing.I changed the timing capacitor and it cleaned up nicely.
A square wave has a 50% duty cycle. That's not possible to do with the schematic you posted. You can get close to a square wave, but it's still not a square wave. To get a square wave you put a flip flop on the output or fiddle with diodes.is this the best I can expect as a square wave
What error are you getting? What format is the file?I can't attach it.....
