NE555 Monostable: OUT stuck HIGH after power cycle — fixed by oscilloscope probe contact
sghioto
Joined Dec 31, 2017
8,766
A cmos 555 reset pin has a much higher internal pullup resistance allowing that RC delay circuit to be effective.
If you must use a NE555 this circuit is effective in providing a delayed reset, D1 optional.
38,952
It appears the 555's internal Reset pin pulls up C5 too fast, making the RC delay ineffective.
Is the RC approach on the Reset pin not viable for the NE555? Is there another method we should consider?
It should be viable, but why did you not try the circuit I posted in post #17 with the added 100kΩ resistor?
Otherwise you could use the transistor reset circuit in post #21.
