NE555 ic getting hot and servo doesn't work
mrnmir
Joined Nov 1, 2022
6
Hi there,
My ne555 timer circuit doesn't work, overcurrent is also detected. I post my scheme, pcb and proteus results. It works pretty fine in proteus (RV1 and C2 values are changed as in real.
Any ideas?
KeithWalker
Joined Jul 10, 2017
3,628
Where is the power connected on the PC board? Make sure it is the right way round.
If the IC is getting hot then there is either:
1. A short on the circuit board.
2. A component is inserted the wrong way round.
3. A component is the wrong value or faulty.
To trouble shoot it:
1: Do a continuity check on a blank board. Do a visual check for solder bridges.
2. Do a careful visual check on the orientation of the components.
3. Measure the values of the passive components and check the diode.
If all else fails, replace the IC.
Alec_t
Joined Sep 17, 2013
15,171
If the pic is showing the solder side of a single-sided board then it looks as though the IC pins are the mirror image of what they should be.
