You are right. I assumed that it was SMD without even thinking about it.If the pic is showing the solder side of a single-sided board then it looks as though the IC pins are the mirror image of what they should be.
| Thread starter | Similar threads | Forum | Replies | Date |
NE555 Monostable: OUT stuck HIGH after power cycle — fixed by oscilloscope probe contact | General Electronics Chat | 21 | |
| C | TLC555 There is Voltage peak at the beginning | PCB Layout , EDA & Simulations | 15 | |
NE555 timer pin5 | Digital Design | 13 | |
NE555 timer issue? | Digital Design | 15 | |
| G | Strange signal from CD4069 | Digital Design | 32 |
