Trying to switch P channel MOSFET direct from NE555 - But we have failure
gray-b
Joined Aug 4, 2025
89
Trying to switch P channel MOSFET IRF9540PBF-BE3 direct from NE555
Power supply is 12v DC
Tried all? sample circuits from Google, but I just cannot get it to switch on or off
The U15 LED is oscillating away, with 11V and no effect on U21 . But as soon as I connect the NE555 output signal to G1 directly, U15 switches off, and U21 comes on. Something is dragging down the NE555 output.
Any advice or guidance, please.
gray-b
Joined Aug 4, 2025
89
Hi Eric
With U15 'ON' measurement at G1 = 11.8v
With U15 'ON' measurement at D2 = 0.062v
With U15 'OFF' measurement at G1 = 10.7v
With U15 'OFF' measurement at D2 = 0.092v
I hope that helps
sghioto
Joined Dec 31, 2017
8,763
Are you sure U20 is connected correctly?
Readings don't add up.
You say when U15 is OFF the voltage at D2 is 0.092 but you mention U21 is ON.
Is R27 installed?
With U15 OFF the voltage at G1 should be practically zero
Roxford
Joined Sep 19, 2025
7
I didn't look up the specs on your MOSFET but having the one that is responsive to low signal levels is a plus. I have used these MOSFETS to drive stepper motors.IMG_20250921_100256.jpg
dl324
Joined Mar 30, 2015
18,521
It would be helpful if you used standard component designators - U is typically used for integrated circuits. LEDs use D, CR, or LED, MOSFETs use Q or M.
And show all connections.
You can avoid the unnecessary colors by printing to B&W PDF and posting a clip from that.
Does your schematic editor allow you to create your own symbols? The one used for the 555 timers is essentially useless.
gray-b
Joined Aug 4, 2025
89
Just tried a new MOSFET and its the same.
If I disconnect pin3 (output) of NE555 then LED U15 comes 'ON' but U21 still stays 'OFF'
However if I short G1 to ground, I can get U21 LED to come 'ON' and 'OFF'
This gives me the impression that the MOSFET is working, but its something to do with the resistors, or even having U15 in the circuit.
gray-b
Joined Aug 4, 2025
89
I'd say that R25 = 100Ω not 100k.
Changed R25 100k resistor to 100 ohms, removed R27 1k resistor, and replaced it with a link (which meant U15 was then disconnected).
Hey presto the output of U21 is working, with an 'ON' at 11.8 volts and an 'OFF' at 2.3 volts. 100 ohms 0.25 watt resistor is getting VERY HOT.
AnalogKid
Joined Aug 1, 2013
12,294
You don't need R25 and R27.
Maybe. The U20 gate threshold voltage could be as low as 2 V. The bipolar 555 datasheet chart for high output voltage indicates that this should not be a problem at low output currents, but some extra margin wouldn't hurt. You could decrease R25 to 10K, and increase R27 to 2.2K.
ak
