I'm having trouble getting a response from A7670 GSM module.
yashas.hp
Joined Jan 25, 2026
6
I have been having some issues with an A7670E GSM module. This is my first time using any GSM module and I just wanted to check if it was working fine. I'm using ESP32 with micropython.
This is the code I've been trying to use:
from machine import UART, Pin
import time
pwr_key = Pin(5, Pin.OUT)
pwr_key.value(0)
time.sleep(1)
pwr_key.value(1)
time.sleep(15)
print("rebooted")
# Test common baud rates
baud_rates = [9600, 19200, 38400, 57600, 115200]
for baud in baud_rates:
print(f"Testing baud rate: {baud}")
uart = UART(2, baudrate=baud, tx=17, rx=16, timeout=1000)
time.sleep_ms(500)
uart.write(b'AT\r\n')
time.sleep_ms(2000)
response = b''
while uart.any():
response += uart.read()
print(f"Response: {response}")
uart.deinit()
time.sleep(1)
and this is the output I'm getting (apparently garbage response):
rebooted
Testing baud rate: 9600
Response: b'\x00'
Testing baud rate: 19200
Response: b'\x00'
Testing baud rate: 38400
Response: b'\x00'
Testing baud rate: 57600
Response: b'\x80'
Testing baud rate: 115200
Response: b'\x00'
Fonhuaicho
Joined Apr 10, 2026
6
A7670 modules are usually pretty reliable, so the issue is often related to power or UART communication settings.
A few basic things to check first:
  • stable supply voltage/current (these modules can draw high current spikes),
  • correct baud rate,
  • common ground between MCU and module,
  • and whether the module responds to a simple AT command in a serial terminal.
Also check if the status LED gives any network or boot indication. A weak power supply is one of the most common causes of “no response” issues with GSM modules.
