My first PCB design
King2
Joined Jul 17, 2022
163
If I were getting this made by a PCB house, I would choose double sided layout and put a ground plane on the bottom side. For this board layout, all traces except GND would appear on the top side.
Is this a design you are talking about ? double sided design
blue is bottom layer and red is top layer
34,817
Your board is a simple layout that turns out well on a single sided layout.
There is little advantage to go with double sided PCB.
Is this board ready to send to PCB manufacturing house ? Or Does it need more improvement?
Add test points for + - power, a external connector/header for reset, a led for power indication, a 'blink' led and some PORT pin header for diagnostics and maybe a few extra ground headers for easy attachment of test equipment like logic probes. The ISP programming header is also a very good addition.
dl324
Joined Mar 30, 2015
18,329
It looks to me like you have a decoupling cap in the same place as the crystal and it's not connected.
Why do you have that ugly wire jog on C6?
Your layout has too much whitespace for my liking.
King2
Joined Jul 17, 2022
163
added a external pushbutton for reset, a led for power indication
this is latest design I don't see anything wrong with C6 and crystal
dl324
Joined Mar 30, 2015
18,329
Boards are more aesthetically pleasing when components are aligned. R3 perpendicular to R1 and R2 for no reason looks awkward. As is the irregular spacing of C5, R1, and R2.
There's no reason for the bend in the trace from the LED to R3.
You omitted the second decoupling cap you had in your original schematic.
Board layouts are easier to read if you don't obscure things (designators for C1 and C2) or show irrelevant layers (the green stuff over/under the crystal. You should turn off the origin markers.
The top mounting holes don't look aligned. Was that intentional?
ericgibbs
Joined Jan 29, 2010
21,442
hi K,
What is the planned use for this PCB.?
Consider if you have input to the PIC Ports from say an external unit, how do you plan to connect the 0V/Common from the external unit to your PCB.?
E
King2
Joined Jul 17, 2022
163
Why not connect the ISP pins?
There is no harm in doing so now instead of having to use jumper cables.
yes it can be done in the design. In fact I am thinking of making it a double layer PCB. I would also find it easier to add a second de coupling capacitor and ISP connection with microcontroller
King2
Joined Jul 17, 2022
163
I added everything in this design. This is a double sided PCB. I hope design meets all the requirements.
RED is top layer
BLUE is bottom layer
ericgibbs
Joined Jan 29, 2010
21,442
hi K,
Are the component holes Plated Thru Holes [PTH}, if not, how will you solder the pins on the components side of the PCB.? [Blue Track]
E
BTW: What about C3 ????
