sorry, but cud u explain to me what do you mean by follower? what if i remove the 7404? the output of the 555timer will only give 5V isit because its TTL? I cant set it to 12V because the DC voltage actually represents the solar panel, which outputs 19Vdc and 0.3A... and could you explain why p-mos can be used? i know im asking a lot of questions but really.... the datasheets are very confusing! sorry....and high voltage inverter.... meaning like 7406?
A 555 is not a TTL device, though at 5V it strongly resembles one. I suspect this isn't a coincidence.ive gone through the data sheet... so many parameters... which 1 is the key parameter that i need to know so that i can properly switch on n off my switch? skory.gylcomp.hu/alkatresz/irfz44.pdf
For eg how did u know i need 10V on the gate? or for this type of mosfet it's fixed?
