Mosfet for boost converter
BobTPH
Joined Jun 5, 2013
11,523
Or you could just choose a mosfet with the parameters you need. You can get mosfets that Are fully on at 4 V, why are you not using them?
Bob
Audioguru again
Joined Oct 21, 2019
6,826
He is not using a "logic level" Mosfet because his output voltage is at least 220V.
Also, the thing must switch at the very high frequency of 100kHz so the gate drive current must be high enough to quickly charge and discharge the high gate capacitance of the Mosfet.
Audioguru again
Joined Oct 21, 2019
6,826
I must be missing something? What does gate voltage have to do with the Vds? Logic level to my simple knowledge only means the gate voltage.
He wanted to use an IRF740 which has a max Vds of 400V and can pass 6A for a moment when its gate-source is 10V. Lookup an IRL741, it does not exist.
shortbus
Joined Sep 30, 2009
10,050
That isn't what you said in the quote I was responding to.
My question had nothing to do with a mosfet that doesn't exist. It was your statement about logic level mosfets not working to pass 220V that I was questioning.
MrAl
Joined Jun 17, 2014
13,708
can you give me a example schematics
This kind of circuit works well.
Instead of the LED use a fast diode, capacitor, and some minimum resistance to keep the voltage from going too high.
The NPN transistor can be almost any small NPN like the 2N2222 or similar.
You can try different value inductors also.
Be sure to simulate first. Keep an eye on the BE junction reverse voltage peak on Q1.
There is a single transistor version but you have to wind your own tapped inductor, Search "Joule Thief".
Danko
Joined Nov 22, 2017
2,169
psoke0
Joined Mar 31, 2017
205
View attachment 207524View attachment 207527
thank you
