Boost Converter Not Giving Output When I Put MOSFET on Both VIN and EN
akash123kumar
Joined Aug 13, 2025
11
Problem Description (Simple Explanation):
I am using an MT3608 boost converter (3.7–4.2V battery → 5V).
I want the boost to turn OFF completely when my BUCK +5.2V supply is present.
So I used a P-channel MOSFET to disable the EN pin.
This part works fine.
But I also don’t want any leakage/backfeed voltage at the boost output when the boost is OFF.
So I tried to route both the Boost VIN and EN pin through the MOSFET.
After doing this:
Main Issue:
  • The boost converter does not give output when load is connected.
  • Even at 10 mA load, it doesn’t start.
  • At 150 mA, also no output.
  • But if I enable EN directly through MOSFET, and give buck input directly the boost works normally.
  • So the problem is coming because VIN is also going through the MOSFET.
What I Tested:
  • I checked MOSFET separately → it does not pass enough current (10–150 mA) in this configuration.
  • EN pin alone works because EN pin uses very small current.
  • When MOSFET drives VIN, the boost cannot start because the MOSFET adds voltage drop or is not fully ON.
What I Want:
  • No backfeed voltage on boost output when boost is OFF
  • Boost should supply up to 150 mA when ON
  • A simple solution using MOSFET or ideal diode
What I Think Is Wrong:
  • MOSFET body diode is causing reverse current
  • MOSFET is not fully turning ON (Vgs issue)
  • Boost needs high startup current, but MOSFET is limiting it
  • Maybe MOSFET needs back-to-back configuration to block reverse voltage
Need Forum Help For:
  • Correct MOSFET configuration to block backfeed
  • Should I use back-to-back MOSFETs or an ideal diode IC?
  • Any simple fix so boost can start properly under load
ronsimpson
Joined Oct 7, 2019
4,900
I think EN needs a pulldown resistor to make it run.
You cold invert the circuit and use a N-MOSFET to pull EN low and a pullup resistor to turn it off.
