Audioguru again
- Joined Oct 21, 2019
- 6,826
Bob, a highpass filter does not create distortion, instead it reduces lower frequencies causing any distortion in the input signal to have a higher percentage.
Thanks bud.Bob, a highpass filter does not create distortion, instead it reduces lower frequencies causing any distortion in the input signal to have a higher percentage.
it Is possible to get nonlinearity down to about 1 part in 200,000 using bipolar transistors and feedback.I've abandoned the attempt to get linear amp. from an inherently non-linear device.
Which will distort any waveform except a pure sine wave. Take any waveform with harmonics, and put it through a high pass filter. The waveform wiill change. That is a form iof distortion.Bob, a highpass filter does not create distortion, instead it reduces lower frequencies causing any distortion in the input signal to have a higher percentage.
Doesn’t a cascode remove the effect of that caoacitor?How do you propose to eliminate that capacitor?
A cascode configuration greatly reduces Miller capacitance - the capacitance between the output and the input of an amplifier. It is used to improve the bandwidth.Doesn’t a cascode remove the effect of that caoacitor?
Bob
