The button had a 5th prong for some reason I twisted it up and away from the board, it might seem it's connected but it's not.What is that connection on the side of the switch I circled in red?
Yep, I just tried it that's exactly the case.OK, but like I said before if the 10K resistor is removed the trigger switch should only work one time. Is that the case?
Actually you were correct about the .693RC. The timing looks short on the video. Adding a 100uf in parallel with the 330 should be just about spot on.a 10k resistor giving me a time interval of about 3.3s
Noted, will drop buy and get a 100uF tmrw. Thanks alot for the help btw, really appreciate it I was really stuck.Actually you were correct about the .693RC. The timing looks short on the video. Adding a 100uf in parallel with the 330 should be just about spot on.
